Captive Portal with 2FA in Nebula
This article describes how to enable and use Two-Factor Authentication (2FA) for a Captive Portal SSID in Zyxel Nebula Control Center (NCC).
2FA enhances network access security by requiring users to enter a one-time verification code generated by an authenticator application (for example, Google Authenticator) in addition to their Nebula cloud credentials.
This feature is supported on selected cloud-managed access points (see the supported model list in NCC).
Prerequisites
  • Nebula Control Center organization and site configured
  • Cloud-managed AP with firmware supporting Captive Portal + 2FA
  • SSID configured with Nebula Cloud Authentication
  • User account registered in Nebula
  • Authenticator application installed on the client device (e.g., Google Authenticator)
Configuration Steps
  1. Log in to Nebula Control Center.
  2. Navigate to:
    Configure → Access point → SSID advanced settings
  3. Select the desired SSID.
  4. Under Sign-on method, choose:
    Sign-on with Nebula cloud authentication
  5. Enable the toggle Two-Factor authentication (2FA).
  6. Click Save to apply the configuration.
Once enabled, users authenticating through the Captive Portal will be required to complete 2FA enrollment (first login) and verification.
End-User Authentication Flow (Smart Device Example)
When a user connects to the configured SSID:
Initial Login
  • The user enters their Nebula username/email and password.
  • Click Login.
2FA Enrollment (First-Time Setup)
  • The portal prompts the user to set up Google Authenticator.
  • The user scans the displayed QR code using the authenticator app.
  • Alternatively, a manual setup key can be entered.
  • Click Next.
Account Linking
  • The authenticator app generates a one-time verification code (OTP).
  • The user enters the code in the Captive Portal.
  • Click Verify.
Successful Enrollment
  • The system confirms that 2FA is successfully enabled.
  • The user gains network access.
For subsequent logins, only the OTP verification step is required after entering credentials.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
