Networked AV Mode - ATEN Partnership
More and more audio and video system are transforming their traditional Matrix Switch infrastructure to industry-standard IP-based network technology. This change brings flexibility to easily scale AV networks as well as extends to longer distance. Traditional AV system makers are less familiar with IP-based network setup, especially with IGMP setting. Detailed IGMP parameter could easily be ignored, which results in a major impact on the system performance.
Supported Model List:
  • XS3800 Series (available since 4.70 Firmware)
  • GS2220 Series (available since 4.70 Firmware)
  • XGS2210 Series (available since 4.70 Firmware)
Networked AV Mode
An intuitive web interface redesigned with chosen Networked AV features to give you an instant view of the current status, with a condensed function menu to help you maintain and configure with ease.
There are 2 options for the setup wizard: basic settings and advanced settings. Choose the one which fits your applications before starting.
  • Basic Mode
  • Advanced Mode
Basic: For default IP / VLAN environment
Advanced: To create a dedicated AV VLAN in a mixed network and do inter-switch link aggregation
Have a look at the Dashboard:
Enjoy the new benefits of our new feature!
Check out the Press Release:
Open Press Announcement
Still questions on that feature?
Be in touch with our Support Team:
Contact us!
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
