Download Firmware from MyZyxel for your Security device (FLEX, ATP, USG, VPN, ZYWALL)
This article will show you how to download the latest firmware versions for your Product easily. It´s important to keep products up to date to avoid issues, protect them from security risks, and have the latest feature set on hand.
Our devices usually use the "Cloud Function" to automatically install a Firmware Upgrade, but you may want to maintain the device manually.
In that case, you can download the last 2-3 versions from Download Library.
Download Library
Go to Download Library and enter your device model in the search field
Download Library
Click on the “Download” button next to the device you are interested in
Navigate to the left Site -> Devices Management -> Firmware Download
Choose & Download
Step 3: Choose & Download
Now you can select from Dropdown your device and download the last 3 available versions.
Choose & Download
That is all. You can now manually upgrade your device with one of these firmware versions!
Articles in this section
Was this article helpful?
5 out of 20 found this helpful
Share
