Security Services - Blocked IPs & False-Positives for Anti-Malware & IP Reputation Filter
This article will explain how to check blocked IPs and how to check false-positives for anti-malwares and IP reputation filter (URL Threat Filter & DNS Threat Filter).
Check Threats via Threat Intelligence
You can check viruses via our Threat Intelligence website
https://threatintelligence.zyxel.com/malware
1) Anti-Malware
For Anti-Malware, please navigate to
Monitor -> Security Statistics -> Anti-Malware
Make sure that the "collect statistics" is enabled, otherwise, the firewall won't record any viruses detected.
Anti-Malware statistics page
1.1 For False-Positives
If you are not sure if this is a false-positive or not, please contact Zyxel Support.
However, if you know that the file is secure and you want to allow it, you can do so by navigating to
Configuration -> Security Service -> Anti-Malware -> Block/Allow List
Then you can add the signature of that false-positive.
Anti-Malware allow list rule
2) IP Reputation Filter
This section will talk about blocked IPs and how you should handle them.
For Reputation Filter, please navigate to
Monitor -> Security Statistics -> Reputation Filter
Make sure that the "collect statistics" is enabled, otherwise, the firewall won't record any URLs detected.
URL Threat Filter statistics page
2.1 Verify the IPs detected
Our devices use the database of Webroot for it's IP Reputation filter.
You can verify the result of our device here:
https://www.brightcloud.com/tools/url-ip-lookup.php
2.2 Prevent certain IPs of getting blocked
First you should verify the result of our device with other IP Reputation services like Cyren, Cisco, Trendmicro, Symantec or Proofpoint. When they all are the same opinion, that the IP is clean, then you can add the IP to the whitelist without fear, that it could still cause harm to your network.
You can find the white list under the following path:
Configuration -> Security Service -> Reputation Filter -> IP Reputation -> White List
IP reputation allow list
You can only add IPs to the white list. It's not possible to add URLs or FQDNs.
Articles in this section
Was this article helpful?
3 out of 6 found this helpful
Share
