The followings are the recommend CLI commands for Nebula Security Gateways, Switches and Access Points:
(You may use Ctrl+F to search)
Security Gateways:
| Command |
Description |
| show running-config |
Show current device configuration |
| show version |
Show the device model, firmware and build information |
| show system uptime |
Show how long the device has been running since its last boot up |
| show port status |
Show statistics for the Ethernet ports |
| show isakmp policy |
Show all VPN IKE SAs |
| show crypto map |
Show VPN phase 2 setting |
| show sa monitor |
Show VPN tunnel uptime |
| show logging entries |
Show last logs entries |
| show interface all |
Show interface information |
| show ip dhcp pool |
Show DHCP pool configuration |
| show ip dhcp binding |
Show current DHCP client |
| show arp-table |
Show device current ARP table |
| show secure-policy |
Show firewall configuration |
| show zon lldp neighbor |
Show LLDP information |
| ping <ip|hostname> |
Ping ip address or domain name |
| traceroute <ip|hostname> |
Execute traceroute from the device |
| nslookup <hostname> |
Resolve domain name |
Switches:
| Command |
Description |
| show version |
| show system-information |
| show interface status |
Show all ports link speed and up-time |
| show mac address-table all |
Show device current MAC address table |
| show pwr |
Show current status and configuration of PoE |
| show lldp info remote |
Show neighbor LLDP information |
| show logging |
| show ip |
Show current management IP |
| show ip name-server |
Show current DNS server configuration |
| show ip arp |
| mac-flush |
Flush MAC address table |
Access Points:
| Command |
Description |
| show version |
| show port status |
| show users all |
Show all current users logged in to the AP |
| show wireless-hal station info |
Show connected clients |
| show cpu all |
Check CPU status |
Check interface status |
| show mem status |
Check memory status |
| packet-trace interface br0 |
Capture tcp packets |
