This article will provide links to weekly firmware hotfix files and final candidate release firmware revisions for the following security gateways:
The following is the changelog for the 4.65 Patch 0 Wk 28 firmware datecode:
- Fix: 2FA page did not change certificate.
- Fix: IPv4 routing failed after interface was recovered.
- Fix: Issue with displaying long username.
- Fix: SSL VPN port back to WWW standard port.
- Fix: Device-HA sync issue.
- Fix: System logging page display issue.
- Fix: IPv6_group for service-object Wiz_2FA issue.
- Enhancement: Remove SSL VPN proxy mode support.
ZyWALL/USG Series
| Product Model | Code/Revision | FCS Firmware (4.65 Patch 0) |
Weekly Update (4.65_Patch0_ITS-WK28-r100632) |
| USG40 | AALA | Download | Download |
| USG40W | AALB | Download | Download |
| USG60 | AAKY | Download | Download |
| USG60W | AAKZ | Download | Download |
| USG110 | AAPH | Download | Download |
| USG210 | AAPI | Download | Download |
| USG310 | AAPJ | Download | Download |
| USG1100 | AAPK | Download | Download |
| USG1900 | AAPL | Download | Download |
| USG2200 | ABAE | Download | Download |
| USG20-VPN | ABAQ | Download | Download |
| USG20W-VPN | ABAR | Download | Download |
| ZyWALL 110 | AAAA | Download | Download |
| ZyWALL 310 | AAAB | Download | Download |
| ZyWALL 1100 | AAAC | Download | Download |
The following is the changelog for the 5.02 Patch 0 Wk 28 firmware datecode:
- Fix: IKEv2 cannot be established with specific character.
- Fix: Add check for dns server setting when showing interface status.
ATP Series
| Product Model | Code/Revision | FCS Firmware (5.02 Patch 0) |
Weekly Update (5.02_Patch0_ITS-WK28-r100674) |
| ATP100 | ABPS | Download | Download |
| ATP100W | ABRW | Download | Download |
| ATP200 | ABFW | Download | Download |
| ATP500 | ABFU | Download | Download |
| ATP700 | ABTJ | Download | Download |
| ATP800 | ABIQ | Download | Download |
USG FLEX Series
| USG FLEX 100 | ABUH | Download | Download |
| USG FLEX 100W | ABWC | Download | Download |
| USG FLEX 200 | ABUI | Download | Download |
| USG FLEX 500 | ABUJ | Download | Download |
| USG FLEX 700 | ABWD | Download | Download |
VPN Series
| Product Model | Code/Revision | (5.02 Patch 0) | Weekly Update (5.02_Patch0_ITS-WK28-r100674) |
| VPN50 | ABHL | Download | Download |
| VPN100 | ABFV | Download | Download |
| VPN300 | ABFC | Download | Download |
| VPN1000 | ABIP | Download | Download |
