Nebula - Problems getting DAC cables to running on my Nebula Switch e.g. XGS1930
In case you are not able to connect some of the fibre optical ports to DAC cables on a Nebula managed switch, chances are that you have to log in manually to the web interface and change the respective settings:
Currently as of December 2019, this setting is not available via the Nebula Control Center, but exclusively to the web interface of the devices using DAC, e.g. Nebula-managed XGS1930.
Articles in this section
Was this article helpful?
2 out of 2 found this helpful
Share
