Zyxel PoE12-3PD Nebula - Overview and Installation Guide for PoE12-3PD
The PoE12-3PD is a Gigabit PoE Extender designed for point-to-multipoint PoE applications, effortlessly extending the range of power and data connectivity when your devices are located far from a power source or connection to a PoE switch. It features four RJ-45 Gigabit Ethernet ports, offering one PoE++ PoE input port with up to 60W power input and three PoE output ports for your devices. Instead of connecting to an AC adapter, connecting via a PoE switch enables better visibility for network management to cover the edge of your network. It features three PoE+ ports to power a variety of PoE devices, including IP cameras, VoIP handsets, IoT devices, sensors, PoE switches, and wireless access points. The PoE12-3PD is ideal for both residential and commercial network environments.
Disclaimer!   This article offers a general overview of the series and may not apply uniformly to every model, software/firmware version. Before purchasing or using the device, please consult the model/version-specific documentation or reach out to technical support for accurate information.
Flexible PoE connection for versatile devices: The PoE12-3PD utilizes four Gigabit RJ-45 ports with PoE, offering both data and power over the same Ethernet cable. The IEEE 802.3bt input port supports up to 60W for the PoE extender, while the 802.3at PoE+ output ports (Port 1-3) deliver up to 30W per port to your devices. It extends the PoE connection beyond the standard maximum distance of 100 meters, reaching even to the edge of your network. This device efficiently expands network capability for office, smart home, or industrial environments.
Built-in with one Gigabit IEEE802.3bt PoE++ (60W) input port and three Gigabit IEEE802.3at PoE+ output ports: Up to 45W power budget to set up versatile devices at the edge of your network.
Monitor status anytime anywhere through Nebula Cloud: With support from Nebula, you can monitor the status of the PoE12-3PD through the Nebula control center via both the web interface and mobile app, enabling convenient access anytime, anywhere.
Important Notes:
  • Ensure proper direction of installation: Ensure the ground cable is connected to a grounding terminal to effectively protect against lightning and high-voltage surges.
  • Do not connect Ethernet devices to power during installation.
  • Avoid overlapping Ethernet cables connected to OUT (protected LAN) and IN (Surge) to prevent high-voltage surge transfer.
  • Make sure the on-site grounding terminal has an earth resistance of less than 5 ohms or complies with electrical regulations. If unsure, consult an electrician or relevant authorities.
Installation Steps
  • Grounding Connection:
-Secure the PoE12-3PD's ground cable to an on-site grounding terminal using a grounding screw (not included).
  • Connecting Protected LAN:
-Connect an Ethernet cable (less than 20 cm) from the OUT port of PoE12-3PD to the Ethernet device to be protected.
  • PoE Connection:
-Use an Ethernet cable to connect the PoE input port to your PoE switch and connect the output ports to your PoE devices.
By following the installation guidelines for the PoE12-3PD, you will extend the power and data connectivity for your PoE devices, ensuring they receive stable and efficient performance even at a distance from the power source
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
