Nebula Compatibility - Compatible List of Devices Series
As the Zyxel product portfolio and Nebula Cloud Solution continue to evolve, maintaining a complete list of compatible devices in a Knowledge Base article can quickly become outdated. Therefore, this article provides general information about Nebula compatibility rather than a complete device list.
Nebula Cloud Solution enables you to deploy, configure, monitor, and manage your network from virtually anywhere. Support for additional Zyxel devices and features is continuously being added.
For the latest list of compatible devices, log in to Nebula and navigate to Help > Supported Devices.
Help Center > Device Function Table
Here below you can see all the models and features available in Nebula currently:
Supported models and firmware are as below:
Access Point
The following Access Points are currently supported by Nebula Cloud Solution: NWA240BE, NWA30BE, NWA50BE, NWA50BE Pro, NWA55BE, NWA90BE, NWA90BE Pro, NWA110BE, NWA130BE, NWA210AXv2, IAP500BE, WBE510D, WBE530, WBE630S, WBE660S, WBE665S; NWA220AX-6E, WAX620D-6E, WAX640S-6E; NWA55AX PTP, NWA55AX Pro, NWA110AX, NWA210AX, WAX655E, NWA300H, WAX510D, WAX610D, WAX630S, WAX650S, NWA50AX, NWA50AX Pro, NWA55AXE, NWA90AX, NWA90AX Pro; NWA1123ACv3, WAC500, WAC500H, NWA1123-AC Pro, NWA1123-AC HD, NWA1302-AC, NWA5123-AC HD, WAC5302D-Sv2, WAC6103D-I, WAC6303D-S, WAC6502D-E, WAC6502D-S, WAC6503D-S, WAC6552D-S, WAC6553D-E, NAP102, NAP203, NAP303, NAP353, NWA1123-ACv2. For the most up-to-date compatibility information, please refer to the Supported Devices section in the Nebula Help Center.**
Switch
The following Security Appliances are currently supported by Nebula Cloud Solution: USG FLEX 50H, USG FLEX 50HP, USG FLEX 100H, USG FLEX 100HP, USG FLEX 200H, USG FLEX 200HP, USG FLEX 500H, USG FLEX 700H, ATP100, ATP100W, ATP200, ATP500, ATP700, ATP800, USG20-VPN, USG20W-VPN, USG FLEX 50, USG FLEX 100, USG FLEX 100W, USG FLEX 100AX, USG FLEX 200, USG FLEX 500, USG FLEX 700, NSG50, NSG100, NSG200, NSG300. For the most up-to-date compatibility information, please refer to the Supported Devices section in the Nebula Help Center.
Firewall
Security Routers
The following Security Routers are currently supported by Nebula Cloud Solution: USG LITE 60AX, SCR 50AXE. For the most up-to-date compatibility information, please refer to the Supported Devices section in the Nebula Help Center.
Accessory
The following Accessories are currently supported by Nebula Cloud Solution: POE12-3PD. For the most up-to-date compatibility information, please refer to the Supported Devices section in the Nebula Help Center.
Articles in this section
Was this article helpful?
3 out of 9 found this helpful
Share
