Supported Devices
ZyWALL 110
ZyWALL 310
ZyWALL 1100
USG40
USG40W
USG60
USG60W
USG110
USG210
USG310
USG1100
USG1900
USG20-VPN
USG20W-VPN
USG2200-VPN
UAG2100
UAG4100
UAG5100
NXC2500
NXC5500
Configure Date/Time
To configure the time and date settings on the ZLD appliance please access the web configuration screen. From the WebUI go to menu, Configuration → System → Date/Time. The following changes can be made from this menu:
- Time and Date Setup – Choose to manually set the time and date settings, or, sync with an NTP server to automatically pull the info. (Note: A Google search can help find NTP servers near your region.)
- Time Zone Setup – Your locations time zone can be selected manually from the dropdown, or, based on GeoIP and NTP server information. (Note: Manually selecting the time zone will offer more reliable time sync.)
- Daylight Savings – Adjust the daylight savings time (if region observes DST). You can enable the daylight savings option and manually enter the start and end dates, or, automatically adjust the clock for daylight savings based on time zone data.
