- Phones are not registering with service
- Verify there is an internet connection to the Zyxel gateway. If you can access the web (internet), internet connection is active.
- 8x8 uses port 5060 & 5061 (5060 is primary) for phone registration
- Verify phone IP settings to make sure it has an IP within the Zyxel gateways LAN subnet. Phone should have a valid LAN IP address, subnet mask, gateway address and DNS server(s).
- Phone connection to service is unstable
- UDP session with VoIP service may be timing out causing the phones to lose connection. Increase UDP session timeout to fix this issue (e.g. 3 minutes or 180 seconds). Additionally, you may want to verify with phone manufacturer/provider to see how often the phone checks registration and increase UDP session timeout on Zyxel gateway based on this info.
- Create a policy control (firewall) rule to allow communications with VoIP provider servers. Depending on geographical zone, 8x8 provides a list of servers on their "Virtual Office Technical Requirements" pdf guide found here. We will use US West Coast servers for this example.
- Create an address object for each subnet described in 8x8s site.
- Create an address group for 8x8 subnet(s) address objects.
- Add a policy control (firewall) rule to allow traffic from these 8x8 addresses to the LAN network where the VoIP phones are located.
- One-way voice traffic or poor audio quality
- Confirm your network is not in a Double NAT. A Double NAT means the device in front of the Zyxel gateway is also a router. Many service providers assign a modem/router combo appliance. To verify if this is the case, do the following:
- Open a web browser and go to https://myip.dnsomatic.com/ or https://domains.google.com/checkip.
- Verify the address with that shown on the Zyxel interface status option in the Monitor menu.
- If addresses do not match, then the device in front of Zyxel gateway is a router. In this case you will need to contact the service provider who assigned the modem/router to you and ask them to bridge the device, so it functions as a modem only.
- Repeat steps a & b after the modem has been set to a bridge state to verify you are no longer in a Double NAT.
- Enable SIP ALG if option is currently disabled.
- Enable bandwidth management on the Zyxel gateway and provide SIP traffic priority on the network.
