Dear Customer,
your country is not supported by EMEA Region Support.
Please go to this page to get your Support.
Click Here
Please type here...
Please note that we can only offer callbacks in English language at the moment!
Continue with Technical Check
Model Name:
Warranty Expiration Date:
Invalid Serial Number
This serial number does not appear to be valid.
Our serial numbers start with “S” and typically contain 13–15 characters.
Without a valid serial number, some services may be unavailable.
Please check and correct the serial number, or remove it and continue without a serial number.
Dear Valued Customer,
Thank you for being a part of the Zyxel family.
Although your product warranty has ended, we are pleased to offer you a special 15%
discount for your next purchase on our Zyxel EU Store
Use the voucher code GEUO67B15 at checkout to enjoy this exclusive benefit.
If your warranty concerns persist, please initiate a Return Merchandise Authorization (RMA) case with a
copy of your invoice, and we'll gladly assist you further.
We're committed to your continued satisfaction with our products and services.
Best regards,
The Zyxel Team
New Feature Need help? Try our Zyxel Search AI feature
Try Now!
Unable to retrieve IPC camera IP address using setup software or router DHCP client list:
Make sure the camera is powered ON and connected to the network using an Ethernet cable.
If the ZyXEL eaZyWizard cannot detect the device, try disabling the computer's firewall to make sure it is not blocking the eaZyWizard scan.
If the IPC camera is not showing up on the router DHCP client list please try rebooting the router.
Press and hold down the RESET button on the IPC camera for 10-15 seconds to delete any configuration on the camera that may be causing the issue.
Contact Zyxel Technical support for additional support. Support is available Monday through Friday from 8AM to 5PM PT @ 800-255-4101 option 5. You can also get email support by completing the "Support Request Form" here.
Problems recording video to NAS/NFS share:
Verify the NAS/NFS status for the directory and make sure the connection has not Failed.
If NAS/NFS status show the connection is Online, please check the directory permission. Make sure the directory has read/write permission.
If the NAS/NFS server has a firewall enabled, please disable to make sure it is not the blocking/stopping the read/write traffic.
Make sure firmware on the IPC camera us up to date
Make sure NAS/NFS server is running the latest build (version)
Possible compatibility issue between IPC and server, please try different server if possible
Unable to register IPC camera to cloud service, software will not run:
Software is only compatible with Windows computers. Running setup wizard is necessary to get the camera registered with cloud service.
Download digital copy of the setup CD if something is wrong with the CD copy. You can download the setup utility from our FTP site here.
Try a different disc drive or computer if possible.
Can’t connect to Wi-Fi:
If the IPC camera is unable to establish a wireless link, please check to make sure the wireless base station is not programmed to hide the SSID broadcast.
Rule out wireless base station encryption as the issue by disabling security and verify the IPC cam can connect. If IPC cam connects on an unsecure network select the lowest security type and see if the camera can connect. Increase the security method each time, issue may be on the security mode being used or special characters on the wireless password. The IP camera supports WEP, WPA and WPA2-personal encryptions.
Disable MAC Filtering on the wireless base station (if enabled).
Camera drops Wi-Fi connection:
Verify the wireless channel setting on the wireless base station. If the AP is set for an automatic channel selection please disable this feature. During an automatic channel selection the wireless base station will disconnect any associated devices while it changes to a different channel.
Check the environment for wireless interference. The cameras support 2.4GHz Wi-Fi standard, if there are too many wireless signals using the 2.4GHz wireless spectrum they can cause interference which will impact the Wi-Fi performance and stability. The stronger the interference, the more impact it will have on the connection. Devices like microwave ovens, baby monitors, cordless phones and Bluetooth utilize radio waves on the 2.4GHz spectrum, these devices will impact the Wi-Fi performance when in use.
Distance can also impact the stability of the Wi-Fi connection. If a client is out of the coverage area or too far (outer limits) where the signal is weak, wireless drops will be an issue. Running a site survey is recommended to detect dead spots and distance the Wi-Fi signal travels.
Make sure the antenna or USB dongle on the IPC cam is secure.
We and our partners use cookies on our site for delivering personalised content, ads and analyzing website traffic. This provides you with better browsing experience. By clicking ‘agree’ or navigating this site, you agree to the use of cookies described in our cookie policy. You can manage your cookie preferences at any time.
