How to diagnose VoIP-traffic using Wireshark
When debugging (diagnosing) an IP telephony service, it is very difficult to analyze VoIP traffic. Is there a more convenient and efficient way to debug VoIP using the Wireshark traffic analyzer?
The Wireshark program implements a convenient mechanism for diagnosing (analyzing) VoIP calls, in particular, you can get a graphical diagram of calls and see how data was exchanged. Wireshark allows you to analyze the SIP protocol and its RTP traffic.
Suppose that during the execution of a VoIP call using Wireshark, network packets were captured and this dump should be analyzed.
Walktrough Steps:
1. Select a SIP or RTP packet from the list (in our example, analyze the RTP traffic). To filter packets, you can enter a value in the Filter field.   sip or rtp to display only a certain type of traffic.
2. Go to the Statistics menu (or Telephony , depending on the version of the program) > VoIP Calls .
The VoIP Calls window opens with a list of VoIP calls.
The list of VoIP calls shows the following information for each call:
    • Start Time: The time the call started.
    • Stop Time: The end time of the call.
    • Initial Speaker: The IP address of the packet source that initiated the call.
    • From: For SIP calls, the INVITE request is displayed in the "From" field.
    • To: For SIP calls, the INVITE request is displayed in the "To" field.
    • Protocol: Protocol.
    • Packets: The number of packets participating in the call.
    • State: Call status.
    • Comment: Additional comments.
3. Select a VoIP call and then click the Graph button (or Flow , depending on the version of the program). The Graph Analysis window will appear with a graphical diagram of the VoIP call data exchange.
In this diagram, it is much more convenient to analyze VoIP-traffic for diagnostics (debugging), but it will require knowledge of the principles of the SIP data transmission protocol (Session Initiation Protocol): https://en.wikipedia.org/wiki/Session_Initiation_Protocol.
KB-00495
Articles in this section
Was this article helpful?
12 out of 20 found this helpful
Share
