To move a device from one organization to another, the user will need to remove it from the site and unregister it in the inventory first.
This topic will have the steps for all Nebula series to unregister them on Nebula CC.
We will also explain what happen to the local configuration when "removing from the site" or "unregister from the organization" in this post.
Gateway(NSG series):
- Steps to remove from Site:
- Go to GATEWAY > Monitor > Security gateway.
- Click Pencil next to Configuration on the top left.
- Click Remove from this site and Save.
(NSG will reboot with default configuration but keeping WAN interface settings.)
- Steps to remove from Organization
- Go to Organization > Inventory, and check the checkbox for your NSG.
- Click “- Unregister” button to unregister NSG from Nebula CC.
(NSG will reboot with default configuration and also reset WAN interface settings.)
Switch(NSW series):
- Go to SWITCH > Monitor > Switch.
- Check the checkbox for your switch and click Move button.
- Click Remove from site and Save.
(NSW will reset to factory default, but the Cloud Connection Status in local WebGUI is Connected.)
- Go to Organization > Inventory, and check the checkbox for your NSW.
- Click “- Unregister” button to unregister NSW from Nebula CC.
(NSW will reset to factory default, but the Cloud Connection Status in local WebGUI is Unregistered.)
Switch(Hybrid switch):
(Switch will reset to default configuration, but the Cloud Connection Status in local WebGUI is Connected.)
- Go to Organization > Inventory, and check the checkbox for your Hybrid switch.
- Click “- Unregister” button to unregister Hybrid switch from Nebula CC.
(Switch will reboot with standalone mode and the Cloud Connection Status in local WebGUI is Unregistered.)
Access point(NAP series and Hybrid AP):
- Go to AP > Monitor > Access point.
- Check the checkbox for your access point and click Move button.
(AP will reboot with default cloud configuration and status Registered when it connects to Nebula CC)
- Go to Organization > Inventory, and check the checkbox for your Access point.
- Click “- Unregister” button to unregister Access point from Nebula CC.
(AP will reboot with factory default, but Hybrid AP will reboot with standalone mode and status Unregistered.)
