Zyxel Firewall USG/USGFLEX/ATP/VPN - Zyxel Firewall crash logging procedure
In case your USG/ZyWall/ATP/VPN/USGFLEX or any other professional firewall or router is crashing, please upgrade to the latest firmware version and collect console logs via the following procedure:
Disclaimer!  This article offers a general overview of the series and may not apply uniformly to every model, software/firmware version. Prior to purchasing or using the device, please consult the model/version-specific documentation or reach out to technical support for accurate information.
Upgrade the firmware
  • Upgrade the firmware to the latest known firmware
Firewall [USG/ATP/VPN] - How to Update/Upgrade Firmware on USG/ATP/VPN
  • Please also check our weekly firmware build. It's possible, that your issue was already fixed in it
Weekly Firmware / Support Version / Lab Version
If the update did not help, please use the console cable to collect console logs for further investigation by tech support.
Connect to the console
CLI Commands [USG Series] - Overview of Helpful CLI Commands for USG Series
Connect to the console port of the USG using terminal software (in this case, we are using Putty)
Once you are in the CLI, use the following command to enhance the logging output:
Router> debug kernel console-level 8
Debug in CLI - Using Console to Access the Serial Port & Use Debug level 8 [Putty & TeraTerm]
Send the console logs to the Zyxel Support Team for analysis if the device still reboots and you clearly see messages about this in the logs.
Articles in this section
Was this article helpful?
2 out of 5 found this helpful
Share
