Zyxel WRE6606 Range Extender - Repeat an SSID without Wizard on the WRE6606
This guide will assist you in configuring your Zyxel WRE6606 Repeater to extend your Wi-Fi network without using the easy mode configuration wizard.
Before you begin, ensure that the Zyxel WRE6606 Repeater is powered on and that you have access to a computer or laptop with Wi-Fi capability.
Configure WRE6606 as Repeater
  1. Set the Device to Repeater Mode
    • Locate the mode switch on your Zyxel WRE6606 Repeater and set it to "R" (Repeater Mode). For more detailed instructions, refer to the manual provided with your device.
  2. Connect to the Repeater’s Network
    • On your PC or laptop, connect to the SSID (network name) specified on the sticker at the bottom of the repeater unit. Enter the password (WPA2-PSK) also provided on the sticker.
  3. Access the Configuration Page
    • Once connected to the repeater's Wi-Fi network, you should be automatically redirected to the login page. If this does not occur, manually navigate to http://zyxelsetup or http://192.168.1.2 in your web browser.
  4. Log In to the Repeater
    • Use the following default credentials to log in:
      • Username: admin
      • Password: 1234
  5. Skip the Easy Mode Setup
    • Choose to skip the "eaZy 123" setup wizard to configure the device manually.
  6. Manual Configuration
    • Navigate to the following settings:
      • Configuration > Network > Wireless LAN 2.4 (or 5GHz) > AP Select
  7. Select the SSID to Repeat
    • From the list of available SSIDs, select the network you wish to extend and click "Continue."
  8. Enter the Password for the Selected SSID
    • Input the password for the network you are extending.
  9. Optional: Customize the Extender’s SSID and Password
    • If desired, you can change the SSID and password of the repeater to match your preferences.
  10. Save and Apply Settings
    • The device will now configure itself based on your input. Once the configuration is complete, you should be able to connect to the extended network.
Troubleshooting
  • No Redirection to Login Page: Ensure you are connected to the repeater’s network. If the issue persists, try accessing the configuration page directly using the IP address or URL provided.
  • Incorrect Credentials: If the default login credentials do not work, check if they were changed during a previous configuration attempt.
  • Configuration Issues: Double-check the SSID and password you entered to ensure they are correct.
Additional Information
  • Firmware Updates: It’s a good idea to check for any available firmware updates for your Zyxel WRE6606 Repeater to ensure optimal performance and security.
  • Technical Support: For further assistance, visit Zyxel’s support website or contact customer service.
By following these steps, you should be able to successfully configure your Zyxel WRE6606 Repeater without using the easy mode setup wizard, extending your Wi-Fi network efficiently.
Articles in this section
Was this article helpful?
5 out of 18 found this helpful
Share
