Firewall (USG Series) - Configure Email logs & Daily Report
This article describes how to add your email address to receive daily reports from a USG.
Step-by-Step:
  • Go to Configuration > Log & Report > E-mail Daily Report and select Enable Email Daily:
  • Enter a valid email address:
  • Choose which Report Items should be included:
  • Press Apply when all settings are done:
Log Settings
  • Go to Configuration > Log & Report > Log Settings and mark a System Log and click on Edit:
  • Enable the "Active" checkbox:
  • Enter the necessary info of Email Server, Email Address, etc:
  • If you want to use SMTP Authentication, then please enter the needed information:
  • Now you can choose which Logs or Alerts should be included in the Email Log:
  • When you have filled out all needed fields, just click OK:
Articles in this section
Was this article helpful?
2 out of 6 found this helpful
Share
2 comments
  • I'm a new owner of a Zywall USG40 router.    I can't seem to send out e-mail... reminiscent of failures in Netgear etc (other minimalist home gateway routers) that only use Port 25... an ancient, obsolete method.     Egad, can't someone show an example using a widely-accepted service like google mail aka "gmail"?       Why show a Taiwanese mail server?   Please.
  • I succeeded first using smtp.charter.net and port 587.    Then, eventually, smtp.gmail.com   and port 587.       There is no lag with the charter-sent mail but a 5 to 7 minute lag in the google-sent mail.
    I followed instructions found in this rather recent Zyxel advisory:           https://mysupport.zyxel.com/hc/en-us/articles/360003862480-ZLD-Email-Report-Logging-Setup-Gmail-
