Nebula Site-to-Site VPN — Configure Site-to-Site VPN Between Nebula Gateways Using Standard VPN and VPN Orchestrator
Nebula provides two different methods for creating Site-to-Site VPN connections between Nebula gateways.
VPN Type Description Typical Use Case Key Characteristics
VPN Orchestrator Centralized SD-VPN topology and VPN management Enterprise and large multi-site deployments Full Mesh/Hub-and-Spoke management, VPN Areas, centralized orchestration
Manual-link VPN Manually configured IPSec VPN tunnels between Nebula or third-party devices Third-party VPN interoperability, advanced/custom IPSec deployments Manual peer configuration, custom IPSec policies, full administrator control
Nebula SD-VPN Automated VPN connectivity between Nebula gateways Simple branch-to-branch VPN connectivity Automatic tunnel creation, cloud-managed topology, simplified deployment
Note: Nebula SD-VPN and VPN Orchestrator support VPN connectivity only between gateways located within the same Nebula organization. For VPN deployments between different organizations or third-party devices, Manual-link VPN must be used.
Note: The configuration examples in this article are based on a Zyxel H Series firewall. The same procedures can also be used for USG FLEX and ATP Zyxel firewalls.
Related Article:  For IPSec VPN deployments where one or both peers are located behind NAT, refer to the following guide: Site-to-Site VPN with NAT on Zyxel USG FLEX H - Configuration Guide
This article explains deployment scenarios:
  • VPN Orchestrator
There are two topologies you can use when creating a site-to-site VPN: Site-to-Site and Hub-and-spoke. This article would take the Site-to-Site scenario as an example.
  • Scenario 1 — Standard Nebula Site-to-Site VPN
Nebula Manual-link VPN
Nebula SD-VPN
  • Scenario 2 — Nebula VPN Orchestrator
Objective:
192.168.168.0/24 can communicate with 192.168.160.0/24
192.168.160.0/24 can communicate with 192.168.168.0/24
  1. Navigate to "Organization-wide > Organization-wide manage > VPN orchestrator"
Enable both VPN gateways and select the subnet(s) that you want to communicate with each other.
https://us.v-cdn.net/6029482/uploads/7E11V4HKLXQD/3.jpg
2. We use the external interface as a VPN WAN link by default
If you want to change the VPN WAN link, please navigate to "Site-wide > Configure > Firewall > Site-to-Site VPN", select the Primary/Secondary interfaces that you want.
3. Navigate to "Organization-wide > Organization-wide manage > VPN orchestrator"
and click the refresh button of your browser
This example demonstrates how to configure a manual IPSec Site-to-Site VPN tunnel using Nebula Manual-link VPN between two Zyxel firewalls managed by Nebula Control Center. Nebula Manual-link VPN can also be used to establish IPSec VPN tunnels between a Zyxel firewall and third-party firewalls, provided that both peers use matching IPSec parameters.
Site Device Local Network WAN Interface
Site 1 FLEX 500HP 192.168.88.0/24 ge1
Site 2 FLEX 200H 192.168.112.0/24 ge1
Step 1 — Configure Manual-link VPN
Navigate to Nebula: Site-wide > Configure > Firewall > Site-to-Site VPN
Step 2 — Configure Manual-link VPN
Check the result.
Nebula SD-VPN
This example demonstrates how to configure an automatic Site-to-Site VPN connection using Nebula SD-VPN between two Nebula gateways located within the same organization.
Site 1 FLEX 500HP 192.168.170.0/24 ge1
Site 2 FLEX 700H 192.168.231.0/24 ge1
Step 1 — Configure Nebula SD-VPN on Site 1
Under the Nebula SD-VPN tab:
  1. Select the primary WAN interface.
  2. Enable the local subnet(s) that should participate in the VPN tunnel using the Use VPN toggle.
  3. Enable Nebula SD-VPN.
  4. Select the desired VPN Area.
  5. Set the VPN topology to Site-to-Site.
  6. Configure NAT Traversal if the device is located behind NAT.
Step 2 — Configure Nebula SD-VPN on Site 2
Navigate to: Site-wide > Configure > Firewall > Site-to-Site VPN
  2. Enable the local subnet(s) that should participate in the VPN tunnel.
  4. Select the same VPN Area used on Site 1.
  6. Configure NAT Traversal settings if required.
Check the result.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
