Zyxel Networks recognizes that advanced users—such as ISPs, system integrators, and networking professionals—often require enhanced flexibility to customize network behavior according to specific deployment needs. Historically, developing and deploying custom firmware, including OpenWrt-based solutions, on Zyxel access points frequently involved unofficial methods or bypassing the original firmware. Such approaches could be complex, inconsistent, and carry potential risks.
With this new approach, developers can now create and develop OpenWrt-based software directly on Zyxel Networks hardware through a standardized and secure method, eliminating the need to search for firmware vulnerabilities or rely on unofficial modification paths.
Supported Zyxel models:
| Model Name | Supported Firmware |
| NWA130BE | V7.30 |
| NWA50BE | V7.30 |
| NWA55BE | V7.30 |
| NWA240BE | V7.30 |
| NWA210BE | V7.30 |
| NWA30BE | V7.30 |
| NWA55AX PRO | V7.10 |
| NWA55AX PTP | V7.10 |
Note: Please note that once OpenWrt has been installed, restoring the device to the original factory firmware may not be possible. OpenWrt is third-party firmware intended for advanced use. Devices modified with custom firmware are not eligible for Zyxel support, warranty, or RMA services under any circumstances, including hardware-related issues.
Notice on Warranty and Custom Firmware
OpenWRT Waiver Registration
Register your device to unlock bootloader capabilities.
- Password (Last 3 Digits) - During registration, you may be asked to enter the last 3 digits of your password. If your password includes letters or symbols, please enter the last 3 characters instead (case-sensitive).
- You can register multiple devices at once.
- Generate token
Registration Successful
Execute Token via Console
- Connect the console cable
- Open terminal (115200 8N1)
- Log in as admin
- Enter _aladdin token command
- The device will reboot automatically
For detailed step-by-step instructions, please refer to the official documentation at the following link.
0 commentsPlease sign in to leave a comment.
