Zyxel Nebula FWA70 — device and package overview
Nebula FWA70 is a 5G FWA outdoor/indoor router designed to provide internet access via a mobile network.
The device can be installed either indoors or outdoors and comes in an IP55-rated enclosure.
The FWA70 is suitable for scenarios where wired internet is unavailable or unstable, as well as in cases where a backup connectivity channel is required to ensure higher network reliability. Easy setup and management with quick deployment via Nebula (using the Nebula Mobile app for fast setup and the Zyxel One app to help find the optimal location and orientation for best signal reception), plus centralized management and monitoring through the Nebula platform.
Recommended Use Cases
  • Business: a backup 5G connection to ensure uninterrupted operation in case of fixed-line outages.
  • Home: connection to an existing router via Ethernet to distribute internet access throughout the home network.
  • High-demand scenarios: multi-gigabit performance for 4K content streaming and remote work.
Key Advantages
High 5G Speed
Support for 5G NR Sub-6 GHz (NSA and SA modes)
Download speeds up to 7 Gbps (theoretical)
Reliable Signal Reception
4×4 MIMO
4 built-in directional 5G/4G antennas
Antenna gain up to 9 dBi per element (depending on band)
Reliable Outdoor Operation
IP55 rating
Operating temperature: –30…55 °C
Surge protection: K.21 6 kV
Wind resistance: Level 12 (tested for mast/pole mounting)
Single-Cable Installation (PoE)
1× 2.5GbE RJ-45 PoE LAN — power and data over a single Ethernet cable
PoE: IEEE 802.3af/at 2.5G
Easy Setup and Management
Quick setup via the Nebula Mobile app
The Zyxel One app helps find the optimal location and orientation for best signal reception
Centralized management and monitoring via Nebula
Key Technical Specifications
  • Cellular connectivity: 5G NR (NSA/SA), 4G LTE
  • Maximum 5G speeds: SA — DL 7.01 Gbps / UL 2.5 Gbps; NSA — DL 5.67 Gbps / UL 1.46 Gbps
  • Antennas: 4 built-in directional antennas; up to 9 dBi gain (ultra-high band)
  • Port: 1× 2.5GbE RJ-45 PoE LAN
  • Power supply: IEEE 802.3af/at 2.5G PoE
  • SIM: nano-SIM
  • Indicators/buttons: 2 LEDs (status and signal strength), Reset button
  • Power consumption: < 15 W (peak)
  • Operating conditions: –30…55 °C, IP55
  • Protection: K.21 6 kV / DM 1.5 kV; wind resistance Level 12 (pole mounting)
  • Dimensions / weight: 150 × 68 × 200 mm; 660 g
Key Features
Networking & Security
  • IPv4 / IPv6 dual-stack support
  • Router mode and Bridge (IP pass-through) mode
  • NAT/NAPT, port forwarding, port triggering, and DMZ support
  • Integrated firewall with SPI, DoS protection, and application-level filtering
  • VPN pass-through support for secure remote connectivity
Management & Control
  • Local and remote management via Web GUI (HTTP/HTTPS)
  • Cloud-assisted setup and local management via Zyxel One App
  • TR-069 remote management with TR-181 data model
  • CLI / SSH access for advanced configuration
  • APN, network selection, and frequency band management
  • Device orientation (azimuth) and power consumption reporting
Mobile Connectivity
  • 5G NR (Sub-6 GHz), 3GPP Release 16 compliant
  • Supports both Standalone (SA) and Non-Standalone (NSA) modes
  • Up to 7 Gbps download speed (5G SA)
  • 4×4 MIMO support for enhanced performance and stability
  • Backward compatible with 4G LTE, supporting wide FDD and TDD bands
Antenna & Hardware
  • Four embedded high-gain directional 5G/4G antennas (up to 9 dBi)
  • 2.5GbE PoE LAN port for power and data over a single cable
  • LED indicators for device status and signal strength
  • USB port for troubleshooting
The Nebula FWA70 package includes
What Is Included
  • Nebula FWA70 device
  • PoE injector (802.3af/at, 2.5G)
  • 10 m flat Ethernet cable (white, 8P8C)
  • 1.8 m Cat.6 Ethernet cable (white, 8P8C)
  • Quick Start Guide
  • DoC and safety warnings
  • Wall-mounting screws
  • Pole/mast mounting clamps
What Is Not Included
Additional mounting accessories for alternative installation methods are available as optional items (sold separately).
Pole & Glass Mounting Table Stand Mounting
Nebula FWA70 License Pack
Articles in this section
Was this article helpful?
0 out of 1 found this helpful
Share
