Вот переведённая и отредактированная версия статьи на английском без внутреннего пункта:
Do all Zyxel access points come with a power adapter or PoE injector?
No, not all of them.
Some Zyxel access point models, such as the Zyxel NWA130BE NebulaFlex Tri-Band Ceiling Mount WiFi 7 Access Point, do not include a PoE injector or power supply unit (PSU). This is clearly stated on the product page:
Please note: This access point is not supplied with a PoE injector or PSU, see accessories tab.
Important: This device is specifically designed for modern workplaces, where Power over Ethernet (PoE) is commonly used, making a separate power source unnecessary in most cases.
How can you check what’s included?
Before purchasing, it’s strongly recommended to:
- Review the datasheet — it includes:
- key specifications;
- supported features;
- physical characteristics;
- what is included in the standard package.
- Download the datasheet from the Zyxel download portal (Download Library).
Tips before buying:
- Make sure you have a PoE switch or injector available in your network setup.
- Check the Accessories tab on the product page.
- Always download the datasheet to avoid surprises.
