In this article, we will take a look at how to set up a Captive Portal and redirect on the Controller or the Access Point.
For this we will need to meet the following requirements:
We need an NXC, a Zyxel PoE Switch, Zyxel PoE Access Point, a Mobile Client. We need to have already set up a guest account.
Topology
In this example, we will work with the Standard VLAN Setting.
Setting Up the Network
Go To:Configuration -> Network -> Interface -> VLAN
Choose a fixed IP Address in the Range of your Gateway (exp. 192.168.1.1 /24)
Please be advised that You have to Setup the Gateway (in this case 192.168.1.254 /24)
Setting Up the SSID:
Go To: Configuration -> Object -> AP Profile -> SSID -> SSID List -> Add
We choose a Name (cp_lab_test) and leave it on the default Security, which is “open.”
Setting Up the Captive Portal
Go To: Configuration -> Captive Portal -> Captive Portal
Now we activate the Captive Portal by clicking on: “Enable Captive Portal”
In the Second Step, we set the Logout IP: “6.6.6.6“
It is advisable to set the Logout IP to a local IP (exp. 10.1.1.10)
Setting Up the Redirect
Go To: Configuration -> Captive Portal -> Redirect on Controller
Click on:
“add”
Source: “LAN_SUBNET”
Destination: “ANY”
Schedule: “NONE”
Authentication: “FORCE”
Login Page: “Controller_default”
Auth. Method: “default”
or
Go To: Configuration -> Captive Portal -> Redirect on AP
We need to Setup the following:
1) Auth. Policy Rule
2) Auth. Policy Group
After that, click on: "Apply"
Testing the Redirect
