This step by step guide shows how to schedule the SSID via Script on USG/ATP/VPN/NXC/UAG. This can be used to turn off/on the broadcast of an SSID for certain times.
Table of Content
3. Disable SSID command (2.4GHz)
4. Disable SSID command (5GHz)
5. Enable SSID command (2.4GHz)
1. Scenario
- On the days off, the guest SSID is not open for use.
- Internet access is blocked but the clients still can access the LAN subnet.
2. Preparation
- Need to know the AP_Group name.
- SSID profile binding by AP Group.
- Need to know the SSID name.
- SSID running times
- schedule run command and concept.
- Schedule run command just can run 1 script only, so configuration needs to be done script by script
6. Enable SSID command (5GHz)
7. Preparation of script-file
- Copy the command to the notepad and save as ".zysh" file.
- The schedule run command is “schedule-run 1 zysh daily 17:00”
- for the loop, it is necessary to enable script call - the next action is disabled the script.
8. Upload script file
Maintenance > File Manager > Shell Script
9. Run the script
- For the first time, it is necessary to manually enter the command to run the script file
- Check the schedule run status command
- Disable the schedule run command
Also interesting:
Do you want to have a look directly on one of our test devices? Have a look here in our virtual Lab:
