Are you looking to optimize your Zyxel networking equipment installation while ensuring the utmost convenience and reliability? Look no further than the comprehensive range of Zyxel Mounting Accessories. In this article, we will look at various mounting solutions designed to install and protect Zyxel networking products from harsh environments: Zyxel Waterproof Enclosure, Zyxel Pole-Mounting-Kits(ZZ0103F and ZZ0106F), Zyxel Wall Mount-Mounting-Kits, Zyxel Ceiling mount with clips, Zyxel Desktop Mount
Waterproof enclosure
Our waterproof enclosure offers robust protection for Zyxel WiFi Access Points, ensuring they thrive in challenging settings. Easily mount your AP on walls or poles with this durable enclosure.
Designed to withstand extreme temperatures ranging from -20°C to 50°C, this enclosure is not only waterproof with a certified IPX5 rating but also features UV-stabilized plastic, extending the lifespan of your AP. It's the ultimate choice for reliable waterproofing
P/N: ACCESSORY-ZZ0102F | P/N: ACCESSORY-ZZ0113F |
Waterproof Enclosure Compatibility List
| ACCESSORY-ZZ0113F | ACCESSORY-ZZ0102F | |
| Description | - Operating temperature range: 50°C to -20°C- IPX5 rating- Wall/Pole mounting (pole mount kit sold separately) | - Operating temperature range: 50°C to -20°C- IPX5 rating- Wall/Pole mounting (pole mount kit sold separately) |
| Dimensions | 311.2 × 250.2 × 87.2 mm | 238.54 × 249.72 × 86.97 mm |
| Weight | 800 g | 639 g |
Supported Models
ACCESSORY-ZZ0113F: WBE630S, WAX610D, WAX620D-6E, WAX630S, WAX640S-6E, WBE510D, WBE530, WAX510D, NWA110BE, NWA130BE, NWA210BE, NWA240BE, NWA110AX, NWA210AX, NWA220AX-6E
ACCESSORY-ZZ0102F: WAX510D, WAX610D, WAX620D-6E, WAX630S, WAC500, NWA110AX, NWA210AX, NWA220AX-6E, NWA1123-AC Pro, NWA50BE, NWA50BE PRO, NWA90BE, NWA90BE PRO, NWA50AX, NWA50AX Pro, NWA90AX, NWA90AX Pro
ACCESSORY-ZZ0103F
- Claws with screw winding as steal belt
- Pole arm
- Ankle between outdoor enclosure and pole arm
- Mounting plate for the leashes on the outdoor enclosure ACCESSORY-ZZ0102F
ACCESSORY-ZZ0106F
T-bar clips
These mounting clips provide an easy and secure solution for installing access points (AP) without causing any damage to the ceiling tiles or grid.
P/N: ACCESSORY-ZZ0105F
| Models: P/N: ACCESSORY-ZZ0105F | Compatible with all Zyxel ceiling-mounted access points |
Wall Mount Arm
P/N: ACCESSORY-ZZ0108F
Overview of the fastening system on our YouTube channel
