How can I remove a device from the web-authentication, so that no extra login / authentication for a dedicated Client is needed to connect to the Internet?
1.) Set the dedicated device which you want to extract from the web authentication in the "DHCP Table" (dashboard) as "reserve" -> set tick for the device
2.) Create an Address object with the name of the device as Host and add the IP address (the IP address from the reserve)
3.) Now you can add an extra rule in "Web Authentication" to allow this specific device to use the Internet without Authentication :
Set now from Source: "DeviceObject" (which you have given to the device in step 2) -> Destination needs to set to Any ->and Authentication needs to be "unnecessary".
This rule has to be at the top because it works from top to bottom and in this case it will allow the client to access the internet without Authentication. All other clients which are not included in this rule needs to authenticate before they will be able to get internet connection.
