To reinstall or transfer the IPSec SecuExtander VPN Client, ensure administrative rights and an internet connection. Uninstall the client from the old computer to release the license for reuse. For a new installation, download the latest version from Zyxel's website, run the installer as an administrator, and follow the prompts to activate the license with your key. If the previous computer is inaccessible due to hardware issues, contact Zyxel Support with your license key and registration email to release the license for a new device.
Note:
Newer versions can be installed directly over the existing version. The prerequisite is that the installation process is again executed with administrative rights.
Re-installation IPSec SecuExtander VPN Clien
- A new installation on another computer also requires reactivation. To release these, the activated client on the old computer must be removed via the uninstall routine.
- Again, with administration rights and a functioning internet connection.
- The uninstall process automatically releases the license for reuse on the authorization server.
Transfer of an IPSec VPN license to a new computer
- Access Installed Programs:
- Navigate to
Settings>Apps>Apps & Features.
- Navigate to
- Initiate Uninstallation:
- Locate the
Zyxel IPSec VPN Clientin the list. - Click on it and select
Uninstall
- Locate the
- Complete the Process:
- Follow the prompts to finish the uninstallation. Ensure the computer is connected to the internet during this process to automatically release the license key for reuse.
Note: The license will only be released for use on another device if the client has been fully uninstalled and the computer was connected to the Internet at the time of uninstallation. If you encounter any problems during this process, please contact support Contact Support
Installing and Activating the VPN Client on a New Computer:
- Download the Latest Version:
- Obtain the most recent version of the Zyxel IPSec VPN Client from the official Zyxel website.
- Run as Administrator:
- Right-click the installer and select
Run as administratorto initiate the installation wizard.
- Follow Installation Prompts:
- Proceed through the installation steps as guided by the wizard.
- Activate the License:
- When you launch the VPN Client, please enter your license key when prompted to activate the software.
Handling Inaccessible or Damaged Hard Drives:
- Contact Zyxel Support:
- If you're unable to access the previous computer due to hardware issues, reach out to the Contact Support
- Provide Necessary Information:
- Supply your license key number and the email address used during the initial registration.
- License Release:
- After verification, Zyxel Support will assist in releasing your license key for activation on a new device.
By meticulously following these steps, you can seamlessly transfer or reinstall your Zyxel IPSec VPN Client license to a new computer.
