In an earlier version of the ZyWALL/USG there has been a bug where the port-negotiation was not working correctly.
As you are not able to configure this via web interface, you need to connect to the device via ssh/telnet or console cable and use a terminal program like Putty or Tera Term.
To change the configuration, you need to use the CLI command to configure the port so it can negotiate automatically.
Router# configure terminal
Router(config)# port status Port1
Router(config-port-status)# negotiation auto
Router(config-port-status)# exit
Router(config)# write
Use the following command to see the current status of each port:
show port status
The same procedure can also be used to set a static port speed.
Please see the below commands for your reference:
show port-grouping |
Displays which physical ports are assigned to each representative interface. |
port status port 1 |
Enters a sub-command mode to configure the specified port´s settings |
Sets the port´s duplex mode. The no command returns the default setting. |
Leaves the sub-command mode. |
Sets the ethernet port connection speed in Mbps. The no command returns the default setting. |
show port setting |
Displays the ethernet port negotiation, duplex and speed settings. |
show port status |
Displays statistics for the ethernet port. |
show port statistics portx interval <5 ... 3600> |
Displays the specified port´s statistics and updates them according to the interval you set. |
