By default, the USG / ZyWALL / ATP Series has an untrusted certificate, and the Hotspot User (Guest) needs to click to continue/skip the certificate message to maybe see the Login Page Information. This article describes the best-known scenario of how to cover that.
Solution
You need to purchase a certificate with an FQDN Name i.e. "hotspot.hotelname.de" (Usually a cheap Domain verified type certificate is enough)
Import the certificate including the private key within the firewall device under
Configuration -> Object -> Certificate and upload it to "My Certificates"- Change under System -> WWW the certificate to upload one
You can decide if you want to keep "Redirect HTTP to HTTPS" active or not. Both can work in the end.
Add an A-Record in the DNS setting to match your preferred: WAN IP to your FQDN Name
Only use WAN IP, if this IP is not used in NAT for HTTP / HTTPS Port and if it´s a static IP, otherwise use LAN IP, but WAN is recommended.
Login by SSH to USG and enter the following commands:
configure terminal
web-auth redirect-fqdn <FQDNNAME>
write
exit- Make sure your LAN Subnet (for Hotspot Users) have ZyWALL as first DNS Server to catch FQDN
With these Best Practice configurations, we can support up to 80% of all clients / mobile phones that can avoid the HTTPS issue or HSTS issue, but also this solution has some limitations.
Limitations and Tips&Tricks
Limitations if the client i.e. Android Phone, iPhone, Mac, Windows 10 .. .. can´t! support Hotspot Detection Feature (older versions, blocked by software...)
- If the Website not support HSTS certificate warning still pop-up but can skip
- If the Website support HSTS (google, facebook..) it shows certificate warning and blocks it (no way to continue from here), in that case, a customer must visit 6.6.6.6 IP configured here to access it.
- You can try to disable "Redirect HTTP to HTTPS" and see if that works better
- A walled Garden list for some known HSTS pages can help to exclude some from Web-Auth first (no authentication) and let customers authenticate when visiting a page without HSTS (Hotspot license required)
For example:
- *.google.com
- *.facebook.com
- The * acts like a wildcard
Note: As soon as there is a new RFC Standard in place, we´ll monitor the situation and update our software versions, to deliver the best solution, which is available in the market, you can monitor it from here: http://www.rfc-editor.org/info/rfc7710
Here is an article that describes a way how to use Let's Encrypt certificates on a USG
