In some rare situations (symptom as following), ZyWALL/USG might not boot up
successfully after firmware upgrade. The following procedures are the steps to
recover firmware to normal conditions. Please connect the console cable to
ZyWALL/USG.
1. Symptoms
• Booting success but device show error message
“can’t get kernel image”
while device boot.
• Device reboots infinitely
• Nothing displays after
“Press any key to enter debug mode within 3 seconds.”
for more than1 minute.
• Startup message displays
"Invalid Recovery Image”.
The message here could be
“Invalid Firmware”
“Invalid Recovery Image”
2. Recovery Steps
• Press any key to enter debug mode
• Enter
atkz –f –l 192.168.1.1
to configure FTP server IP address
• Enter below command to bring up the FTP server on port 1:
atgof
• The following information shows the FTP service is up and ready to receive firmware
- You will use FTP to upload the firmware package. Keep the console session open in order to see when the firmware update finishes.
- Set your computer to use a static IP address from 192.168.1.2 ~ 192.168.1.254
- No matter how you have configured the ZyWALL/USG’s IP addresses, your computer must use a static IP address in this range to recover the firmware.
- Connect your computer to the ZyWALL/USG’s port 1 (the only port that you can use for recovering the firmware).
- Use an FTP client on your computer to connect to the ZyWALL/USG. This example uses the FTP command in the Windows command prompt. The ZyWALL/USG’s FTP server IP address for firmware recovery is 192.168.1.1
- Log in without the user name (just press enter).
- Set the transfer mode to binary. Use “bin” (or just “bi” in the Windows command prompt).
- Transfer the firmware file from your computer to the ZyWALL/USG (the
command is “put 310AAAC0C0.bin” in the Windows command prompt - 310AAAC0C0.bin is to be replaced with the filename of your file).
• Wait for the file transfer to complete.
• The console session displays
“Firmware received”
after the FTP file transfer is
complete. Then you need to wait while the ZyWALL/USG recovers the
firmware (this may take up to 4 minutes).
• The message here might be
“ZLD-current received” = “Firmware received”.
“done”
when the firmware recovery is
complete. Then the ZyWALL/USG automatically restarts.
• The username prompt displays after the ZyWALL/USG starts up successfully.
The firmware recovery process is now complete and the ZyWALL/USG is
ready to use.
If the process is done several times, but the problem
remains, please collect all the console logs and send to ZyXEL/USG for further
analysis.
Please Note:
If one of the following messages appears on the console, the process must
be performed again:
./bin/sh: /etc/zyxel/conf/ZLDconfig: No such file
Error: no system default configuration file, system configuration stop!!
