In this article, we'll compare the USG FLEX H Series to the USG FLEX Series and highlight why the USG FLEX H Series has the upper hand. The USG FLEX H Series comes with several gigabit ports, a user-friendly in-house operating system, and excellent performance for tasks like UTM and VPN. It also offers faster boot times and improved CPU performance.
Disclaimer!
This article offers a general overview of the series and may not apply uniformly to every model. Prior to purchasing or using the device, please consult the model-specific documentation or reach out to technical support for accurate information.
Highlight USG FLEX H Series
- Port Flexibility, Multi-gig, and PoE+
- Supports speeds 10 Mbit/s, 100 Mbit/s, 1 Gbit/s & 2,5 Gbit/s
- Brand-new powerful uOS for better usability
- High-performance throughput (including UTM and VPN)
- Up to 3x firewall throughput
- All-in-one VPN Client
- Enhanced Security
USG FLEX H Series Overview
| Feature | USG FLEX 100H(P)* | USG FLEX 200H(P)* | USG FLEX 500H | USG FLEX 700H |
| Max. Concurrent Sessions | 300,000 | 600,000 | 1,000,000 | 2,000,000 |
| Max. UTM Concurrent sessions | 200,000 | 400,000 | 800,000 | 1,600,000 |
| Total Physical ports (ALL Configurable) | 8*1GbE | 6*1GbE, 2*2.5GbE | 8*1GbE, 4*2.5GbE | 2 Multi-GbE (up to 10G), 2 SFP+, 8*1GbE, 2*2.5GbE |
| PSE port | 1 port 30W | 1 port 30W | 2 ports, total 30W | 2 ports, total 30W |
| (USG FLEX 100HP) | (USG FLEX 200HP) | |||
| USB 3.0 | 1 | 1 | 1 | 1 |
| Housing Type | USG20/40 | USG60 | USG110 | USG310 |
| Fanless | Y | Y | N | N |
| SPI Firewall Throughput | 3Gbps | 5Gbps | 10Gbps | 15Gbps |
| VPN throughput | 750Mbps | 1.2 Gbps | 2 Gbps | 3 Gbps |
| UTM throughput (AV & IDP) | 750Mbps | 1.5 Gbps | 2.5 Gbps | 4 Gbps |
| IPS throughput | 1,5 Gbps | 2 Gbps | 3,5 Gbps | 6,3 Gbps |
| Max. Concurrent IPsec VPN tunnels Gateway to Gateway IPsec VPN Tunnels | 50 | 100 | 500 | 1000 |
| Gateway to Gateway IPsec VPN Tunnels | 20 | 50 | 200 | 300 |
| Concurrent SSL VPN users | 25 | 50 | 200 | 500 |
- *USG FLEX 100H and 200H also have PoE built-in version available as USG FLEX 100HP/200HP.
PoE+ function with ports :USG FLEX 100HP P2; USG FLEX 200HP P2; USG FLEX 500H P3, P4; USG FLEX 700H P3, P4. - *1 VPN throughput measured based on RFC 2544 (1,424-byte UDP packets)
- *2 Anti-Malware throughput is based on express mode
- *3 UTM Throughput measured by using the industry standard HTTP performance test (1,460-byte HTTP packets)
- All Testing done with multiple flows
The data for the USG FLEX series is shown below for quick comparison.
| Feature | USG FLEX 100(W) | USG FLEX 200 | USG FLEX 500 | USG FLEX 700 |
| SPI firewall throughput | 900Mbps | 1.8Gbps | 2.3Gbps | 5.4Gbps |
| VPN throughput | 270Mbps | 450 Mbps | 810Mbps | 1.1Gbps |
| UTM throughput (AV & IPS) | 360Mbps | 550 Mbps | 800Mbps | 1.35Gbps |
| Max. TCP concurrent sessions | 300,000 | 600,000 | 1,000,000 | 1,600,000 |
| Max. concurrent IPSec VPN | 40 | 100 | 300 | 500 |
| Concurrent SSL VPN users | 30 | 60 | 150 | 150 |
| Max VLAN interfaces | 8 | 16 | 64 | 128 |
| Max. concurrent devices logins | 64 | 200 | 300 | 800 |
Other Benefits
- Keyword Search - Save your time to search each feature
- My Favorite - Add frequently used pages to your favorites.
- High DH Group - Support Diffie-Hellman groups up to DH30 to ensure a highly secure connection
- Secure Boot - Verify the validity of system files and protect firmware from unauthorized changes
- Wide Range of IKE Cipher Suites - Maximize interoperability with third-party VPN devices through a variety of IKE Cipher Suites
- Security & Reliability - IKEv2 is a widely adopted VPN protocol known for its security, reliability, and efficiency compared to L2TP over IPSec. It ensures exceptional compatibility with various VPN components.
- Easy Wizard & Effortless Migration - Utilize a script for easy compatibility with native OS-based IKEv2 VPN clients such as Windows, macOS, iOS, and Android (StrongSwan)* For Android devices, you must download the third-party strongSwan app. Please note the support of L2TP/IPSec has been removed from Android 12.
- SecuExtender Streamline Secure Connectivity - Get one installation for a secure tunnel with options for IKEv2 IPSec VPN and SSL VPN
- SecuExtender Multi-Platform Licensing - Simplify your experience with a single license key that covers Windows and macOS
| Function | USG FLEX 200 | USG FLEX 200H |
| System boot time | 4 minutes | Within 3 minutes |
| Local Firmware Uploads | 60 seconds | Within 30 seconds |
| Restore configuration | 60 seconds | 3-5 seconds |
