Sometimes, it might be demanded, that you set off the lighting / LED of your Nebula Access Point.
The Nebula Control Center offers two different approaches to solving this requirement:
• Disable all lights on all AP's in the site:
Navigate to the following menu to deactivate the AP lights for the entire site:
Site-wide -> Configure -> Access points -> AP & port settings- Disable lights on specific AP's in a site.
Site-wide -> Devices -> Access pointsSelect via checkbox the APs affected and click on the "Add"-Button left above the table and click on the search bar for "Tag" - it will then show you the option to Tag the Accesspoint either with "LED_On", or "LED_Off". Saving this Option will disable or enable all the LEDs of the AP.
