Zyxel AP NAT mode is a network setting on Zyxel access points where the AP itself acts as a DHCP server and NAT (Network Address Translation) device. This mode creates an isolated network for wireless clients. Client cannot communicate with other clients associated with different AP.
Go to Configure > Access points> SSID settings. Add to SSID as "Wi-Fi". Then click "Edit".
Supported model list:
NWA50AX, NWA50AX PRO, NWA55AXE, NWA90AX, NWA90AX PRO, NWA110AX, NWA110BE, NWA130BE, NWA210AX, NWA210BE, NWA220AX-6E, NWA1123-AC HD, NWA1123ACv3, NWA1302-AC, NWA5123-AC HD, WAC500, WAC500H, WAC5302D-Sv2, WAC6303D-S, WAX300H, WAX510D, WAX610D, WAX620D-6E, WAX630S, WAX640S-6E, WAX650S, WAX655E, WBE510D, WBE530, WBE630S, WBE660S
Note: Updated model information is available here Device function table
- The following AP features do not work when NAT mode is on.
a. 802.11r
b. Layer2 isolation
c. Dynamic VLAN (cloud authentication, RADIUS server) - When NAT mode is enabled on non-supported models, Nebula CC does not show any error message. And non-supported models disable any SSID with NAT mode enabled.
- The IP address lease time is 8 hours.
