The Zyxel Nebula Security Gateway (NSG) Series, designed as SMB gateway units, offers an integrated captive portal. This tutorial will show you how to configure it in no time!
- Log in to nebula.zyxel.com
- Choose the respective organization and site that needs Captive Portal configuration
- Navigate to
Site-wide > Configure > Firewall > Authentication method
- choose the LAN interface at which the clients should authenticate and the “Sign-on with: Nebula Cloud Authentication” method
- Enable “Walled Garden” to add addresses that clients can access without authenticating via Captive Portal
- Under Captive portal access attributes, you can choose if the clients are allowed to create accounts and if they can log in with one account from multiple devices
- Under “NCAS disconnection behavior” you can define which clients are blocked when the Nebula Cloud Server is not accessible and click “Save”
Navigate to
Site-wide > Configure > Cloud Authentication - to create a user account with the “Account Type: Guest” by clicking “Add”
- After filling the credentials for the user, set “Authorized” to Yes and click “Create User”
- Click ”Save” in the Cloud Authentication screen once again
Please note: Navigate to
Site-wide > Configure > Firewall > Authentication Methodto add general Walled Garden addresses which are not only applying to a specific authentication method.
See this article on how to configure Captive portal on your Nebula WiFi:
Nebula - Configure Captive Portal on SSID
The account type “User” would need an Active Directory / RADIUS server.
