Zyxel USG Lite 60 AX - How to establish an VPN connection with the USG Lite 60 AX by the macOS Sonoma native VPN client?
The article provides a step-by-step guide on establishing an IKEv2 VPN connection with the USG Lite 60 AX using the macOS Sonoma native VPN client. It instructs users to navigate through the settings to add a user account for remote VPN access, enable the IPsec VPN server, and download the necessary VPN configuration script file for macOS. Users are then guided to install the script file on their Mac device, configure the IKEv2 VPN profile with user authentication details, and successfully establish the VPN connection. Finally, it advises checking the VPN connection status in the monitoring section.
Navigate to Site-wide> Configure > Cloud authentication > To add a user account and allow Remote VPN access.
Navigate to Sitw-wide > Configure > Security router > Remote access VPN > To enable IPsec VPN server.
Download the VPN configuration script file for macOS.
Download the script file of RemoteAccess_iOS_macOS_IPSec_VPN.mobileconfig to the Mac device and navigate to Privacy & Security > Profiles > To install the script file.
Allow to install the script file.
Edit the IKEv2 VPN profile, select 'User authentication,' and then choose 'Username.' After that, input the username and password.
Dial the IKEv2 VPN connection successfully.
Navigate to Site-wide > Monitor > Security router > VPN connections > Check the IKEv2 VPN is established successfully.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
