Zyxel Switches XMG Series Overview- 108HP/XMG-108/XMG-105HP Overview and First Initialization
Zyxel Switches XMG-108 [Overview] -  XMG-108 / XMG-105HP Switch Overview and First Initialization
The Zyxel XMG-100 Series 2.5 Gigabit switches are advanced networking solutions designed to upgrade and expand your network to higher speeds and better performance. Perfect for home, SOHO, or small office users, these switches meet the growing demands of online gaming, multimedia streaming, and faster wireless network connectivity. All ports feature 2.5 Gigabit Ethernet speed, allowing for an easy network speed upgrade. Additionally, this series offers an extra SFP+ slot for high-bandwidth network uplink or access to Network-Attached Storage (NAS).
Disclaimer! This article provides a general overview of the series and may not apply uniformly to every model, software, or firmware version. Before purchasing or using the device, please consult the model/version-specific documentation or reach out to technical support for accurate information.
Quick Setup
This is a non-managed switch, and its setup is straightforward:
  • Connect the Switch to Power: Plug the switch into a suitable power source.
  • Connect to the Network: Use an Ethernet cable to link the switch to a modem or router that has internet access.
  • Start Using the Switch: You can now use the switch, and it will automatically manage the ports for you.
Key Features
High-Speed Connectivity:
  • The XMG-100 Series includes 5- and 8-port models, with all ports supporting 100/1000/2500 Mbps Ethernet speeds with auto MDI/MDIX support. This multi-gigabit capability ensures seamless and rapid data transfer across all connected devices.
Plug-and-Play Convenience:
  • With a plug-and-play design, the XMG-100 Series allows users to easily upgrade their network speeds without needing complex configurations. Simply connect the switch to 2.5G-capable devices and enjoy enhanced network performance instantly.
Silent and Stable Operation:
  • Built with a fanless design, the XMG-100 Series operates silently, making it perfect for any home or business environment. Its sturdy hardware ensures stable performance, contributing to a reliable networking experience.
Cost-Effective Upgrade:
  • The XMG-100 Series allows users to increase their network speed from 1Gbps to 2.5Gbps using existing cables, eliminating the need for additional cabling costs.
Optimized Performance:
  • The series features switches with switching capacities of up to 60 Gbps and forwarding rates of up to 44.6 Mpps. They support auto-negotiation with up to multi-gigabit bandwidth (100M/1G/2.5G), making them excellent choices for LAN parties, high-performance entertainment, and efficient small office/home office (SOHO) networks.
Model-Specific Features:
XMG-108HP:
  • Ports: 8 x 2.5G Ethernet, 1 x 10G SFP+
  • PoE: 8 x 60W PoE++ (802.3bt)
  • Total PoE Budget: 100W
  • Switching Capacity: 60 Gbps
  • Forwarding Rate: 44.6 Mpps
  • Power Consumption: Max 120W, Min 2.74W
XMG-108:
  • PoE: None
  • Total PoE Budget: N/A
  • Power Consumption: Max 9.12W, Min 1.56W
XMG-105HP:
  • PoE: None
Articles in this section
Was this article helpful?
2 out of 8 found this helpful
Share
