Zyxel USG FLEX H Series Nebula - USG FLEX H Series Firewall and Nebula Cloud Integration
In our journey towards seamless integration with the Nebula cloud service, the current functionality of our USG FLEX H Series firewalls reflects a strategic step forward. While full integration is underway, we are committed to optimizing every aspect of this process to ensure robust performance. This article will explore the strides we've made and our vision for the future. Rest assured, the ability to operate in both cloud-managed and standalone modes remains a cornerstone of our design philosophy.
The USG FLEX H Series currently supports cloud monitoring mode via Nebula. Following the setup wizard guide will allow your USG FLEX H device to be easily registered in Nebula. You will then access the USG FLEX H monitoring mode via Nebula and other additional benefits of running Nebula.
Easy onboarding ​
  • The Nebula registration process can be initiated hassle-free directly ​ from the device GUI.​
  • Finish device onboarding via Nebula App wherever and whenever​
Auto Nebula enrollment​
  • Get enrolled in Nebula as soon as users complete device registration​
Centralized Management via Nebula ​
  • Monitor device on/off status​
  • Firmware upgrade operation​
  • Manage firewall licenses​
  • Access remote GUI (requires Nebula Pro Pack)
  • Backup and restore firewall configurations (requires Nebula Pro Pack)​
Features to support in Monitor Mode for on-prem Firewalls​
  • Device status monitoring​
  • Firmware upgrade management​
  • Reverse tunnel management for device
  • Configuration management
Register your devices with Nebula in a few easy steps:
Follow 5 easy steps to register your device and add it to Nebula. Then, go from the web interface of your firewall to the cloud service.
Nebula Centralized Management​
  • Monitoring device
  • Status
  • Ports
  • WAN status
  • Connectivity
  • Remote SSH
  • Remote configurator
  • Config override
  • Reboot device
  • Backup & Restore
Our new Zyxel USG FLEX H Series firewall is progressing towards full integration with the Nebula cloud service. With each update, users will see enhanced capabilities, and soon they will be able to manage their USG FLEX H Series firewalls using Nebula almost just as they do with ATP and USG FLEX devices.
Zyxel USG FLEX H in Nebula soon covering almost all functionalities of FLEX/ATP.
We aim to provide a consistent user experience and logic between Nebula and the device GUI, ensuring that object management and configuration remain intuitive and straightforward.
Stay tuned for more updates as we continue to enhance Nebula's capabilities to provide a comprehensive and user-friendly management experience for all Zyxel devices.
Articles in this section
Was this article helpful?
1 out of 1 found this helpful
Share
