Zyxel Firewall Orange - USG & Zywall - Configuring the Orange fiber optic WAN network on Zywall/USG/VPN series
This detailed guide provides step-by-step instructions on how to set up a PPPOE (Point-to-Point Protocol over Ethernet) connection for use by an Orange operator.
  • Connect to the WEB GUI of your Firewall
Go to Configuration -> Network - > Interface> VLAN
Click Add to start configuring VLAN835 (which is usually requested by the Orange operator).
Note: Your ISP may request a different VLAN, so make sure to inquire about the VLAN you need before configuring it."
Proceed to create your ISP account.
Go to Configuration > Object > ISP
It's important to note that your Orange username always begins with 'fti/'. This step is crucial for establishing a secure and reliable connection to your ISP's network
To complete the setup:
Navigate to Configuration > Interface > PPP > Add (user configuration)
Then, select the interfaces you've just created, specifying the Basic interface as 'vlan835', the Zone as 'WAN', and the Account Profile as 'Orange'. Proceed to fill in the required information as requested by your ISP. This step ensures seamless integration with your ISP's network, facilitating a smooth and uninterrupted connection experience."
Articles in this section
Was this article helpful?
1 out of 2 found this helpful
Share
