Zyxel Nebula Recovery - Auto Configuration Recovery feature
Nebula's Auto Configuration Recovery is a specialized feature tailored for network switches. Its purpose is to automatically revert the switch to a previously stable configuration if a newly applied configuration causes a disconnection from the Nebula network. This functionality is primarily geared toward preserving network stability and mitigating prolonged downtime resulting from configuration errors.
Simply put, if a new configuration causes the switch to disconnect from Nebula, the Auto Configuration Recovery feature takes action. It promptly reverts the switch to its previous configuration, ensuring it's seamlessly reconnected to Nebula. This rollback process is instantaneous, swiftly restoring the network to a stable state.
Activate auto-configuration recovery
To enable Auto Configuration Recovery:
Navigate to Site-wide > Configure > Switches > Switch settings.
Remember to click the "Save" button to apply the changes.
Supported model list, Auto Configuration Recovery feature:
XMG2230 Series, XS1935 Series, CX4800 Series, XGS1935 Series, XMG1915 Series, XGS2220 Series, GS1915 Series, GS1350 Series, GS2220 Series, XS3800 Series, GS1920 Series, XMG1930 Series, XS1930 Series, XGS1930 Series.
An "Auto Configuration Recovery" message in Nebula typically indicates that a device (in this case, a Nebula-enabled switch) has detected a configuration problem and is attempting to automatically recover or return its configuration to a known, stable state.
Click on the "Change Log" button and the system will redirect you to the Change Log page, which will display all configuration changes made during the last half an hour before locking the device. You can press the unlock button once the configuration error has been corrected.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
