Nebula [Mobile App] - Zyxel Nebula Mobile App 3.0
The Nebula Mobile App provides a convenient solution for network management, enabling administrators to swiftly register numerous devices on Nebula Control Center using the QR code scanner. Designed with Responsive Web Design (RWD), it caters to mobile devices like smartphones. Moreover, it offers IT staff an immediate overview of various sites, facilitating real-time monitoring of network status.
To effectively use the Nebula mobile app for various tasks and functions, and to familiarise yourself with the key features of the system, follow these instructions:
Note: At this time, the Zyxel Air app does not support the FWA505 model. We are already working on adding support, and it will be available in one of the upcoming updates.
Nebula Mobile App Quick Guide
Installation & Setup
  • Use the in-app walkthrough to set up organizations, sites, devices (QR/manual), and WiFi networks.
  • Refer to the hardware and LED guides for installation and status indicators.
Monitoring & Insights
  • Centrally view 3-in-1 device status.
  • Access per-device/site usage and PoE consumption graphs.
  • Monitor switch/gateway port info and connected device/client status.
WiFi & Device Management
  • Share WiFi login info via phone or QR code.
  • Scan QR codes to register multiple devices.
  • Schedule firmware updates and manage SSIDs.
Troubleshooting Tools
  • Use live tools for reboots, Locator LED, port cycling, cable tests, and connection checks.
  • View device/client locations on a map with photos.
  • Access 7-day alert history and receive push notifications for device and license events.
Support & Licensing
  • View license and inventory overviews.
  • Find tech support and MSP contact info in-app.
To use the Nebula Mobile App on your mobile device, follow these steps:
Install the Nebula Mobile App:
  • If you have an Android device, download the app for Android.
  • If you have an iOS device, download the app for iOS.
Access the Nebula Mobile App:
  • Launch the Nebula Mobile App by tapping on its icon.
  • Once the app opens, click on the "Start" button to begin.
  • Sign in using your registered Zyxel email address and password.
  • Select one organization and one site and click enter to go to Site Overview.
undefined
The dashboard displays the total devices, connected clients, PoE power, WAN throughput and total usage in this site.
  • Device: show how many of your devices are online and offline.
  • Connected Clients: show how many clients are connected.
  • PoE Power: show how much power is used by PDs.
  • WAN Throughput: show the throughput of WAN interface.
  • WiFi Clients: show which client has connected in the past 24 hours.
  • Application: show which application does the clients use in the past 24 hours.
  • Usage: show the network usage of firewall/gateway in the past 24 hours.
To view the current registered devices with MAC addresses as default names:
Open the Nebula Mobile App on your mobile device.
Navigate to the "Devices" section.
You'll see a list of devices displayed, each identified by its MAC address as the default name.
  • Devices with a green status indicator are online, indicating they are currently connected and operational.
  • Devices with a red status indicator are offline, suggesting they are not currently connected or experiencing connectivity issues.
  • Navigate to the "Devices" section.
  • You'll see a list of devices displayed, each identified by its MAC address as the default name.
To use the QR code for device registration on the Nebula Mobile App, follow these steps:
Navigate to the designated Organization/Site where you want to register the device.
Go to the "Devices" section within the Organization/Site.
Click on the "+" button or the "Add Device" option.
If your device has a QR code, use the app's built-in QR code scanner to scan the QR code on the device. Alternatively, you can manually enter the device information if necessary.
Once the QR code is scanned or the device information is entered, the device will be registered on Nebula Control Center (NCC) automatically through the Nebula Mobile App.
  • Wizard adds more friendly guides and instructions
  • New Dashboard provides cleaner site summary and function access
  • WiFi page provides intuitive actions eg. create, disable/enable, share, delete
  • 3-in-1 Devices list is able to add devices directly
  • 3-in-1 Devices list is also able to get firmware notification and schedule an upgrade
  • New 3-in-1 Clients list with block action support
  • New 3-in-1 Clients page also supports Application Visibility and Control
  • The function comparison table of Nebula Mobile App
  v.2.6 v.3.0
Wizard/Add device process
Hardware install guide No Yes
LED guide No Yes
Dashboard(Site Overview)
Device status Separate by model Centralized(3 in 1)
Client amount Only Wireless Wired & Wireless
Top Wireless client Only amount Amount with Usage
Top Gateway clients Top 3 with Usage No
WAN throughput No Yes
Site usage graph No Yes
AP dashboard Top AP & Top SSID No
Cloud saving mode Warning message only Warning & Banner (with setting)
Notification Center
VPN connection disconnection Yes No
License issue related No Yes
WiFi/SSID
Display list Unfold 8 SSID by default Able to create/delete
Share WiFi No Text messaging & QR code
Security options Open
Enhanced-open
WPA1/2/3
WPA 2/3 with NCAS
WPA 2/3 with Radius
Open & WPA2(Private)
NAT mode Yes Coming soon
Landing page Yes (Complicated) No (Coming soon Simpler)
VLAN Yes Coming soon
Rate limiting Yes Coming soon
Device
Location Map/Sitemap Yes
Yes
(Change & Search function coming soon)
Entry From Home, Separate by model Independent tab (3 in 1)
Search & Sorting Only Search Yes (Search function coming soon)
Details Model name
Status
IP (LAN/Public)
MAC address
Serial Number
Configuration status
Model name
Status
IP (LAN/Public)
MAC address
Serial Number
DNS (GW only)
CPU Usage (GW only)
Memory Usage (GW only)
Edit name Yes Yes (also could do from Wizard)
License info No (Only from License tab) Yes
Tag info No Yes
Live tool Connection Test
Reboot
Locator LED
Connection Test
Reboot
Locator LED
LED trouble shooting Guide
Usage graph No Yes
PoE consumption No Yes
Port info Only Switch Switch & Gateway
Port Details & edit Port name
Enable
PoE
Link speed
Type
PVID
Allowed VLAN
PoE schedule
Cable Diagnostic
Power cycle
Port name
Port status
PoE
Link Speed
Type
Cable Diagnostic
Power cycle
(Port Enable, Speed & PVID, type, allow VLAN, PoE setting coming soon)
Client
Client Detail Name
LAN IP
MAC address
Seen on/Connected to
VLAN
Manufacturer
Name
LAN IP
MAC address
VLAN
Manufacturer
Connected time
OS
Usage graph No Yes
Application Usage analysis (per client) No Yes
Block action Yes (Only from client detail) Yes (Not only from client detail, but also direct from client list)
Application visibility view & Action (Per Site) No Yes
VPN topology Remove from v2.6 No
License
Overview Only NCC license Yes (Including security services)
Further Details Only issue status Yes
License Inventory No Yes
License upgrade option No (Force upgrade) Yes
Add License process No (Only support when adding devices) Yes (Add batch licenses process coming soon)
Purchase license redirect to online store No Yes
More feature/Account
Admin Privileges Only user-self Able to see the whole org admins
Support request MSP info
eITS (Create and view)
Forum
MSP info
eITS (Only create)
Forum
Change org/site name Only site name Yes
PoE schedule Yes No
Push Notification Device online/offline
Articles in this section
Was this article helpful?
3 out of 6 found this helpful
Share
