Zyxel NWA130BE AP - Comparison of NWA130BE and WBE660S
In the rapidly advancing world of wireless technology, Zyxel introduces the NWA130BE access point, a groundbreaking device engineered to leverage the capabilities of the emerging WiFi 7 standard. As WiFi 7 paves the way for unprecedented speeds and connectivity, the NWA130BE stands out with its robust hardware and integration with Zyxel's Nebula Cloud Solution. This combination ensures a seamless, secure, and high-speed wireless experience, catering to both businesses and home users. With a focus on flexibility, scalability, and protection, the NWA130BE is designed to meet the demands of tomorrow's connected world.
  • NebulaFlex​
  • Allows seamless coexistence with 4G/5G cellular networks and minimizes interference.
  • Enterprise-grade WiFi 7 Connectivity
  • Eliminates interference between the 5GHz and 6GHz bands
  • 2.5GbE LAN port
  • 2.5GbE uplink port with PoE+
Comparison table NWA130BE and WBE660S
Model Name​NWA130BE​WBE660S
Description​802.11be (WiFi 7) Triple-Radio Unified Pro Access Point​802.11be (WiFi 7) Triple-Radio Unified Pro Access Point
Band​Triple Band​Triple Band
WiFi Speed​BE11000​BE22000
2.4GHz Power​27dBm​29dBm​
5GHz Power​27dBm​28dBm​
6GHz Power​23dBm​28dBm​
Antenna ​Integrated omni-directional antennas​Smart Antenna
Gain​3.0 dBi@2.4 GHz, 4.0 dBi@ 5 GHz, and 4.0 dBi@ 6GHz​3.0 dBi@2.4 GHz, 5.0 dBi@ 5 GHz, and 5.0 dBi@ 6GHz
Uplink Speed​2.5GbE​10GbE (Multi-Gig 1/2.5/5/10G)
Port Number​2​2
PoE​AT​BT/AT
Management​Nebula (Cloud & App)/standalone​
Nebula/Controller/standalone
Articles in this section
Was this article helpful?
1 out of 3 found this helpful
Share
