Nebula - Configure LAN / VLAN interfaces
Easily configure VLANs on your Nebula gateway by accessing Site-wide settings. The user-friendly interface lets you manage WAN and LAN interfaces effortlessly. To edit a LAN interface, click the pencil icon, set IP and subnet details, and explore advanced options. Creating VLANs is straightforward too: click "+ Add," input VLAN info, IP settings, and DHCP configurations. Advanced settings offer DHCP and IGMP Proxy customization for enhanced client control. Simplify network segregation for "Staff" or "Guests" with Nebula.
Creating VLANs and configuring the VLANs on your Nebula gateway is easy.
  • Please navigate to Site-wide > Configure > Firewall > Interface
As you see the interface of Nebula is designed as straight forward and simple as possible.
At the top you can activate, disable and edit your WAN interfaces. Below that you see your LAN interfaces.
Now let us focus on the LAN side.
Editing a LAN Interface
When being in the interface overview:
  • Click the pencil icon to the right of the LAN interface you wish to edit
  • Configure the interface as needed. You need to enter the IP address and subnet mask. In case the USG should be the DHCP server, configure that too
  • Under "Advanced Settings" you can find extended options which can be pushed to the clients per DHCP and IGMP Proxy
Creating a VLAN Interface
In case you would like to create a few VLANs to separate your internal networks for pruposes like "Staff" or "Guests, please go ahead and
  • Click on "+ Add" in the interface overview at the bottom
  • Configure the interface as needed. You need to enter the VLAN ID, IP address and subnet mask. In case the USG should be the DHCP server, configure that too
Articles in this section
Was this article helpful?
1 out of 11 found this helpful
Share
