Nebula Authentication - Captive Portal Setup on a Firewall Nebula Security Gateway
The Zyxel Nebula Security Gateway (NSG) Series, designed as SMB gateway units, offers an integrated captive portal. This tutorial will show you how to configure it in no time!
  1. Log in to nebula.zyxel.com
  2. Choose the respective organization and site that needs Captive Portal configuration
  3. Navigate to
Site-wide > Configure > Firewall > Authentication method
  1. choose the LAN interface at which the clients should authenticate and the “Sign-on with: Nebula Cloud Authentication” method
  2. Enable “Walled Garden” to add addresses that clients can access without authenticating via Captive Portal
  3. Under Captive portal access attributes, you can choose if the clients are allowed to create accounts and if they can log in with one account from multiple devices
  4. Under “NCAS disconnection behavior” you can define which clients are blocked when the Nebula Cloud Server is not accessible and click “Save”
  5. Navigate to
    Site-wide > Configure > Cloud Authentication
  6. to create a user account with the “Account Type: Guest” by clicking “Add”
  7. After filling the credentials for the user, set “Authorized” to Yes and click “Create User”
  8. Click ”Save” in the Cloud Authentication screen once again
Please note: Navigate to
Site-wide > Configure > Firewall > Authentication Method
to add general Walled Garden addresses which are not only applying to a specific authentication method.
See this article on how to configure Captive portal on your Nebula WiFi:
Nebula - Configure Captive Portal on SSID
The account type “User” would need an Active Directory / RADIUS server.
Articles in this section
Was this article helpful?
0 out of 1 found this helpful
Share
