How do I clear the ARP table in ZyWALL/USG?
How to clear ARP-table. You can clear the ARP table in the ZyWALL USG series from the device’s command-line interface (CLI).
Connect to the CLI using the console port or Telnet protocol.
Run the following commands to clear the ARP table.
1. To remove dynamic entries, run the command:
Router (config) # arp-table flush
2. To delete static (permanent) or dynamic entries, you can use the command:
Router (config) # no arp ip-address
KB-00490
Articles in this section
Was this article helpful?
0 out of 2 found this helpful
Share
