Zyxel VMG / AMG Syslog - Setting up logs on your Zyxel VMG / AMG router
Setting up logs on your Zyxel VMG router is essential for monitoring network activity and troubleshooting issues. This guide will walk you through configuring log settings to ensure you capture the necessary data for network management and analysis.
Access the Router’s Web Interface
  • Open a Web Browser: Launch your preferred web browser.
  • Enter the Router’s IP Address: Type 192.168.1.1 (or the router’s specific IP address) into the address bar and press Enter.
  • Log In: Enter your username and password. The default credentials are usually admin, so if you’ve changed them for both fields, you should use your custom credentials.
New Web GUI Example
Navigate to the Logs Settings
  • Maintenance > Log Setting
  • Th following table describes the fields in this screen.
Old Web GUI Example
Articles in this section
Was this article helpful?
2 out of 5 found this helpful
Share
