Zyxel Firewall H Series uOS - Route Trace and Simple and Visual Way to Check Routing
This tool helps administrators understand how the firewall will handle specific network traffic — based on the source or destination IP address and port. It is designed to be simple and visual, making routing issues easier to diagnose.
From your firewall's web interface:
  • Go to Maintenance
  • Select Packet Flow Explore
  • Then choose the tab called Route Traces
  • Input matching criteria:
    • Source IP address (e.g., from your PC).
    • Send live traffic packet to Destination IP address (e.g., a ping).
    • Filter Protocol (e.g., ICMP).
  • Click Capture.
  • Observe the result:
    • Outgoing interface (e.g., GE1, GE2, or VPN).
Example
Suppose a device at 192.168.11.33 attempts to ping 10.1.1.1. Based on a policy route:
  • If destined for 10.1.1.1/32, traffic exits via GE1.
  • If destined for 10.1.1.4/24, traffic exits via GE2.
Route Trace confirms this by displaying:
  • The ICMP traffic type.
  • The matched interface (GE1 or GE2).
For route-based VPNs, it will show the virtual tunnel interface (VTI) as the outbound path, while in policy-based VPNs, the physical interface (e.g., Ge1) is shown.
Note: In ZLD, packets sent through Policy-based VPN, the interface is “doll”.
Articles in this section
Was this article helpful?
0 out of 0 found this helpful
Share
